Hello people,
I just recently got Xperia P and found out that my accelerometer (or some meter thingy) isn't correct. Placed on a flat surface (even the floor) and my temple run is still tilted to the right. Was wondering if anyone experience this?
auto rotate screen option on display settings.
Still the same bro.. Cant anything be done to it?? already feeling like a jackass for buying such a phone
if you are still on warranty, you can send it to a sony service center, you can show them the service test, and see if they can do something, as it is a hardware glitch, there is only limit as what can be done here in the forum.
Bro thanks for your help for the past 2 days..
hope the problem gets solved at the sont service center *fingers crossed*
No problem, keep us posted of the updates
Hi, how was your phone? Did the accelerometer get repaired?
I have the same problem with acelerometer. I use normally the XP till open a auto-rotate app (e.g Gallery) and then I see it's in a forced landscape mode. I need to restart to repair the issue. Sometimes it goes to normal mode by itself after a (long) time.
Sometimes it happens, sometimes not. I didn't detect the cause yet, if there is some.
I just got back my Xperia P recently and found out that it still have the same problem.
Does anyone with Xperia P also have the same problem?
I tried to email sony regarding my problem but I still did not get a reply from them.
anyone having this problem as well?
please help T.T
