Xperia P Accelerometer problem
xJuneBride
Hello people,
I just recently got Xperia P and found out that my accelerometer (or some meter thingy) isn't correct. Placed on a flat surface (even the floor) and my temple run is still tilted to the right. Was wondering if anyone experience this?
52 REPLIES 52
xJuneBride
I've tried the test you suggested. And my result are similar to mithrunpradeep's.
I placed it on the floor to test it. Used acmeter and i still get the same result.
aayushjain1987
Values when placed on floor : and i am having no problems with my device, everything is working as it is supposed to work !!!
profile.country.PH.title
MarlonUk1
Thank you for that screenshot. Slightly_smiling_Face
you still have a wee bit to the right. -0 value, but as you said you have no problem right?
@ xJuneBride  and mithrunpradeep,  I would suggest to try to tap on and off the accelerometer option , see if it re calibrates the phone.if not, you can try to explain this to the sony service center, perhaps show them the result of the service test. this should let them see clearly there is something wrong. Slightly_smiling_Face
aayushjain1987
Everything is fine, i have played NFS Shift too, GT+ racing , Temple Run too. I previously had Neo V too , no issues here, its just misconception
What they are considering as a problem is not a problem indeed, if you keep a phone on horizontal position while in landscape mode, it will remain in landscape mode only, until you tilt the device vertically to set the accelorometer in motion !!
It is more of an hardware like vibrator, rather than software problem, if it is not working in games, its problem of developers not SONY's , phone manufacturers only guarantee , that their device performs basic function as it was supplied by them , if some app developer's coding is not effective , then you cannot blame phone for that !! Dizzy_Face
Check out the details about what actually a ACCELOROMETER is :
http://www.engadget.com/2012/05/22/the-engineer-guy-shows-how-a-smartphone-accelerometer-works/
MarlonUk1
mithrunpradeep' screenshot show a tilt to the right even it is placed on a flat surface. how could that be not an inconvinience? as you can see yours did not have that tilt. so there must be something wrong with their phone.
aayushjain1987
temple run is buggy , i have played it on GB and ICS too.
If they encounter same problem in other games , like racing games too.
MarlonUk1
can you upload the screenshot of your Service test?
MarlonUk1
Not applicable
how to tap on and off the accelerometer settings?? ll upload the image in the next post.
Not applicable
