Hi ^_^ .. i encountered this one REALLY Weird problem . i never had this problem when i use other Xperia Z series .
So , yesterday , it was a good day . I decided to go to the nearest waterfall . i bring Xperia Z2 swimming with me . The water tempreture was about 19 celsius . ( the water came from top of the mountain so it is FRESH WATER and not salted water ) . i snapped a few pictures and record a few video . After the 2 minutes of the joy , my phone screen goes to BLACK . Immediately , i go to my bag and wipe the wetness of my phone with a towel .
When i went back home , the phone was dried . There is no signs of water got inside the phone (the water didn't showed up in the camera lens) . So i charge the phone with Magnetic cable . the notification LED doesn't seems to light up . Ok , second try , i try to charge the phone with USB cable . the notfication LED lights up but it was RED .
i was panicked and right now , the phone is in the bag full of rice to make sure the water didn't got inside .
P:s : The USB flap was closed properly when the accidents happen . I can confirmed this because before swimming with phone , i tested the pressure sensor ( *#*#7378423#*#* > service test > pressure sensor ) and the test passed , means that the flap are firmly closed
P:s : before the incident , i always bring the phone with me , in the bathroom , playing with the rain . And NOTHING has happened . this is why i called this incident a really WEIRD incident
Thanks for reading my thread ^_^
I'm sorry to hear that, contact your local Xperia care and request a vacuum test
Hi. I discovered a new problem with my Xperia Z2 and i need solution fast,
This morning, I try to charge the phone but the LED light just stays on red. The screen is blank just like the phone is OFF. Magnetic cable charging method doesn't work ( the LED wouldn't light up if i charge via magnetic cable) Only charging via the usb cable brings up the red led light.
I Try to repair via Sony pc companion wpbut the computer doesn't detecting my phone.
I hope there is answer for this and this doesn't hurt sony reputation in making phones because i spend a lot of money buying this phone, thanks
