Sony Xperia Sola : Touchscreen Problems
Not applicable
I had bought this xperia sola 2 weeks ago.....it worked like butter since then till today morning......when i discovered that it's touchscreen is not working properly.....
The touch screen is not responding as it should...Sometimes it sens and sometimes not...!!!
As you can see in video...  VIDEO LINK : http://www.youtube.com/watch?v=IjkJaEathV8
1. it's difficult to unlock....   time : 00.04,  2.10
2. then you cant select or delete clock widget (when you touch and hold.....it presumes that u touched ones and opens the clock.)             time :00.24,   2.48
3. Capacitive  buttons are also not responding well...     time :00.27
4. not able to change wallpaper......as when touching and holding in empty region.....it doesn't open the wallpaper widget menu....    time:  00.30,   02.22
    TOUCH and HOLD  is not working....
5. also it have problem in dialing numbers...    time: 00.42
6. things doesn't changes even after restarting....   time :1.39
7. also have problem in app menu....   time : 3.40
In all the whole problem is of touchscreen response......
I have also rest it to factory setting and formatted it's internal memory.....(in case some setting or app has created this problem)  but unfortunately that has also not helped..... Slightly_frowning_Face
also .162 update is not unavailable from sony(it was available earlier)......!!
also sony companion is also not repairing my phone...it says that your phone is upto date.....
and update centre is also saying phone up to date....and is also not showing"update anyway" feature as suggested by some users....
PLEASE HELP !!! ....I have bought this phone just 2 weeks ago... Slightly_frowning_Face Crying_Face
126 REPLIES 126
mhae0217
daye your here in the phillipines too right? what have you done so far? I have my phone in the service center almost a month now but still they said that there still no parts available for the touch pannel? Have you tried updating your fw  to .184?
jalberto
the screen doens't works at all, i updated to last FW adn reset to defautl several times, but nothing works.
Sometimes when is plugged (to wall, not usb port) the screen works.
Any progress out there?
tharrin
The screen will need to be replaced  Slightly_frowning_Face
Mine's been in the service centre for a couple of weeks now, waiting for the new screen to arrive....
ezio1
Even my touchscreen stopped completely responding.
It's been 2 weeks since i dropped it at the service centre.. I'm sick and tired of Sony.. They keep promising to deliver my phone within a couple of days everytime I call.. I'm gonna sell it.. Hopefully I'm gonna find some takers for this piece of crap.. Check out my thread for more info..
http://talk.sonymobile.com/thread/48281
dyaewdonme
Yes, I had it checked in two different service centers now and both said that the touch panel need to be replaced and, as usual, the parts aren't available yet. About the 184, yes, I did update to 184 but still to no avail. It's pretty obvious that the problem is a physical one so updating will probably not help.
mhae0217
mine is still in the service center. Yeah they also told me that the touchpanel needs to be replaced. I'm still waiting for the part to arrive.
It's just really unfair that I just used the phone for 2 weeks without even dropping it and all of a sudden it will go to a major refurbishment like this... unacceptable. Really...
thomasjude47
hi all,
     my device too is having the same problem since last week.Earlier it was intermittent and used to resolve after a restart.Now its permanent.I have updated to.184 couple of weeks ago..I am planning to flash the phone back to .162.will it affect my warranty?
forepost
Hi all. Same touchscreen problem arised approx. in 2 weeks while a traveling few days and my Xperia was in closed pocket box. I have reinstalled firmware many times and it does not help me. But. Found on one russian forum very interesting thing. And it helps to me.
You can try. Try to keep screen of the phone under direct bright sunlight some minutes (10-20). And it will respond like new one, also when not under sunlight. My keep working for 7 hours, but by info from forum, the problem can arise again. But you know now how back it to working conditions. 😃
By my mind - something wrong with lighting sensor, hope the problem will disapear in next software update.
p.s. sorry for errors, gl (but not overheat your Xperia. My, while was in 40 dg heat has a camera button not responding if overheated for 15 minutes) Winking_Face
Message was edited by: forepost
thomasjude47
i noticed that my touchscreen wrks absolutely normal when plugged in for charging,irrespective of usb or wall plug.It becomes fuzzy the moment its unplugged.
I will try out the sunlight thing ,waiting for the sun to rise again...hehe
mr_hopo
The same here, touchscreen seem so have severe issues: Seems to help to hold the phone while using the touchscreen or plugging it to the charger or computer. Probably some kind of grounding is needed. Absolutelty useless for in car navigation: without cable plugged in it doesn´t work at all. Using it on a isolating surface like a bed doesn´t work, too.
So I brought it to the service center after one week, they send it in and made a "firmware upgrade" to 184. Very funny, since this was up to date already. I´ll send it right in again... My last Sony Ericsson phones were good quality, so face the problem Sony!
