I had bought this xperia sola 2 weeks ago.....it worked like butter since then till today morning......when i discovered that it's touchscreen is not working properly.....
The touch screen is not responding as it should...Sometimes it sens and sometimes not...!!!
As you can see in video... VIDEO LINK : http://www.youtube.com/watch?v=IjkJaEathV8
1. it's difficult to unlock.... time : 00.04, 2.10
2. then you cant select or delete clock widget (when you touch and hold.....it presumes that u touched ones and opens the clock.) time :00.24, 2.48
3. Capacitive buttons are also not responding well... time :00.27
4. not able to change wallpaper......as when touching and holding in empty region.....it doesn't open the wallpaper widget menu.... time: 00.30, 02.22
TOUCH and HOLD is not working....
5. also it have problem in dialing numbers... time: 00.42
6. things doesn't changes even after restarting.... time :1.39
7. also have problem in app menu.... time : 3.40
In all the whole problem is of touchscreen response......
I have also rest it to factory setting and formatted it's internal memory.....(in case some setting or app has created this problem) but unfortunately that has also not helped.....
also .162 update is not unavailable from sony(it was available earlier)......!!
also sony companion is also not repairing my phone...it says that your phone is upto date.....
and update centre is also saying phone up to date....and is also not showing"update anyway" feature as suggested by some users....
PLEASE HELP !!! ....I have bought this phone just 2 weeks ago...
For mine - it does not any changes is it pluged or not, while touchescreen not responding properly of course. After "sunbath" it still working properly for more than 30 hours.
it no longer work normal when plugged in.Taking to service center this week
believe it or no ,giving a sunbath works..i just kept it on sunlight(cloudy light) for 10 minutes and now its normal.Lets see for how long it works...
My Xperia stop working after 48 hours, just "sunbath" again for 5 minutes - and it working again. :smileyhappy:. But it ofcourse not a normal way to back phone to work (touchscreen). Hope that this is some software bug and will corrected. Big hope for ICS update.
Thank you sunbath working forme too. When this problem raise up again can you install this software and draw everywhere of screen and upload screen screen shot here.
which software?
Screentouchtest
I want to see which part of screen is unresponsive,
you can actually perform a touch screen test using the service menu, dial *#*#7378423#*#* service test>touchscreen
Before sunbath
http://postimage.org/image/o40a0tn5b/
After sunbath
http://postimage.org/image/r06jjrbmp/
Works fine, maybe its solar powered this why its name sola 🙂
now it makes sense... coz this problem starts when we have a very cold weather. I'll try it... somehow gave me hope. ^^
