Today, I Updated my Xperia XA to 7.0 (nougat) and movil data does not World... I Called to my Internet provier and restared movil settings, and anything Works.... is it an update problem? thanks For your help
Solved! Go to Solution.
battery is bad
all options used
wifi also not working well
i never buy a sony again
because the battery is charching but not working
the best solution now is a new phone
So because of that I will choose another phone. Now I ask the money back. The online store were I bought it will I ask to return the money.
Then I go to a good phone store
When there is a problem then I can ask easy in person.
Hi I have same issue, but I cant find Internet settings under Settings>>more. I can see Network Settings and all I have is reset option.
I have Sony Xperia XA.
How do I get mobile data to work?
@Genji79 wrote:Hi I have same issue, but I cant find Internet settings under Settings>>more. I can see Network Settings and all I have is reset option.
It's under Settings ... Data usage
@RoosjeHoop, very sorry to hear that.
I hope that everything will work out for you with your new device.
@Genji79, The setting to download the Internet settings should be in Settings > More. Have you made sure that you have scrolled all the down? It's usually one of the last options in this menu. You can also tap the small magnifying glass in the top right corner and search for "Internet settings".
Let me know how it goes!
they will try to fix it free
Hi I tried to do the following but under settings>more I do NOT have the internet setting option.
When I searched settings there was also no "Internet setting" option. What should I do?
Hi @Mernan,
Which model and Android version do you have? You can find this information in Settings > (System) About phone.
It's usually placed in Settings > More > Internet settings (at the bottom, so make sure you scroll down as far as you can) or in Settings > Network and Internet > Internet settings.
Please get back to me with your model and Android version!
@StarKing, sorry to hear that.
Could you please elaborate a bit on what behaviour you are experiencing with your device and I'll do my best to assist you!
