I have had my A99 for around 2 weeks with no hitches until today!
It was working normally and then a clunk noise and the following message on screen
CAMERA ERROR TURN CAMERA OFF THEN ON
I tried turning off and on but the switch had no effect and the message stayed on the screen! The only way to get rid of the message was to undo the battery grip and take the camera battery out and put it in again!
It worked normally for a little while then happened again!
I have took a few shots since the second time and up to now it not done it again as yet!
Not impressed have to admit and wonder if anyone come across this problem on there A99?
UPDATE!!
This has happened yet again today after half hour of use so it obviously something wrong with the camera? (different lens and no battery grip today) Hopefully I am going to get it swapped out for a new one?
I will leave this here for others though in case it happens to anyone else?
Message was edited by: mierwin
Solved! Go to Solution.
