A99 error messages?
SOLVED
profile.country.en_GB.title
mierwin
A99 error messages?
I have had my A99 for around 2 weeks with no hitches until today!
It was working normally and then a clunk noise and the following message on screen
CAMERA ERROR TURN CAMERA OFF THEN ON
I tried turning off and on but the switch had no effect and the message stayed on the screen! The only way to get rid of the message was to undo the battery grip and take the camera battery out and put it in again!
It worked normally for a little while then happened again!
I have took a few shots since the second time and up to now it not done it again as yet!
Not impressed have to admit and wonder if anyone come across this problem on there A99?
UPDATE!!
This has happened yet again today after half hour of use so it obviously something wrong with the camera? (different lens and no battery grip today) Hopefully I am going to get it swapped out for a new one?
I will leave this here for others though in case it happens to anyone else?
Message was edited by: mierwin
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
blaireau_photo
Hello mierwin - Welcome to the Sony Forums :slight_smile:
It does sound like there is some kind of internal fault within the camera. As you have had the camera for around 2 weeks, you should be able to get it exchanged by the retailer - but if you need to contact Sony Customer Services instead you can use the details on the following page:
http://www.sony.co.uk/support/en/contacts/dime
Thanks, Simon
7 REPLIES 7
blaireau_photo
Thanks, Simon
jabrady3763
I have had exact same messages and sent my camera 2 weeks ago to the UK sony repair centre at Pencoed.
Yesterday they were requesting I send them my flash although the problem has nothing to do with the flash!
http://www.dpreview.com/forums/post/51192276
See above thread regarding my problem
http://www.dpreview.com/forums/post/51204708
and above thread for another happy sony customer.
Top of the line Sony cameras both with faults....very worrying but the customer service is also very worrying!
mierwin
It is not something you expect I agree on a £2K+ camera but like everything else there bound to be small numbers that develop faults? It nothing like the other famous brand that have more faults than I have ever seen in there high end recent models?
I cannot fault they are going swap mine for a new body and hopefully the new one will be fine : -)
I was gutted when I got the error don't get me wrong and was not a happy bunny LOL!
I have shot over 20K images on the A77 without a hitch so I did expect more from the Pro body of the A99?
As long as it is the small numbers that I have read about I am otherwise over the moon with the results I am getting when the camera works?
Your case about wanting flash is indeed strange unless there something we don't know?
I will keep an eye on your thread to see the outcome?
jabrady3763
Update on my faulty camera.
It was sent back from SONY Pencoed after 3 weeks with them saying they could find no fault?
If any of you with camera technical knowledge would care to watch the fault in action with any words of advise I would be grateful.
I have invested a lot of money in SONY.
https://vimeo.com/67125912
Please forgive the amateurish video!
profile.country.AT.title
fotowolf61
I had the same issue with my A99. The reason is a hardware issue with the apature control. It looks to me that they put too much greese inside on some models, because all my lenses were suddenly spoiled with some greese that came from the a-mount mechanics.
Unfortunatly the camera does not always log internally an camera error. So it took me two times to send the body to our excelent Sony service company (Schuhmann, Linz/Austria). The second time the error message was logged and showed a hardware issue with the apature control. The complete mirror box was changed (which include the apature steering mechanics). Since then I had no issues any more and another 10000 shutter releases.
Maybe this helps you to get your issue fixed.
Regards, Wolfram
PS: Contact the Austrian Sony Service http://www.schuhmann.at/ , I am sure they can help you with your issue.
Nachricht geändert durch fotowolf61
jabrady3763
Thanks Wolfram
I have sent the details of your message to SONY Pencoed who will relay the information to the technician
reinzad
Ok I have the same problem for no reason my camera just stopped working, and up came the message, "camera error turn power of then on" ha what a joke felt like I was on candid camera. Whatever I try it will not work at all, just the message keeps coming back on the screen. Now I paid lots for this camera and all my other Sony cameras and lens, this A99 was bought in April 2013 so do I now take it that its gonna cost me money to get it repaired? If something is faulty inside, oh and this camera hasnt been abused, why should sony not put it right free of charge. It seems there are more people out there with this fault but no one seems to have a solution as to whats causing it.
