XM3 Headphones no longer Noise Cancelling
Crewood
Over the last couple of weeks, my XM3 headphones no longer seem to be 'noise cancelling' in as much as I can hear other people in a room talking which has never happened before.
Normally, when I wear the headphones and turn them on, there has always been a noticeable 'quietening' after a second or so and this no longer happens.
Any advice or help would be greatly appreciated.
12 REPLIES 12
SkyNet404
Specialist
At this point buddy you will need to contact Sony's support, and they will advise you where you can send it for repair based on your location, hope it gets repaired soon.
Crewood
Thanks for the reply, I'm in the UK so I'll try and find their support here.
HannahEd01
Hey Crewood, that should be Pencoed, email at scs@sony.com or call 01656 867347. If you're within the first year, you're going to be covered.
