MEX-BT3800U steering wheel adapter
SOLVED
profile.country.en_GB.title
bingbonguk
Hi, i have a Citroen C4 2005 Hatchback and have bought the Sony unit MEX-BT3800U to fit. I have bought autoleads pc99-x87 wiring harness and pc9-son patch lead for steering wheel controls, here is my newbie question, which socket at the back of the unit do i connect the patch lead too?
Thankyou for any help.
Tags (4)
1 ACCEPTED SOLUTION
Accepted Solutions
Drumzman
Hi bingbonkuk,
Your patch lead will have a 3.5mm jack plug at one end of it (a bit like a headphone style plug) - you connect this to the socket on the back of the MEX-BT3800U marked 'REMOTE IN' (as you look at the back of the unit I believe it's located at the bottom right).
Hope this helps.
1 REPLY 1
Drumzman
Hi bingbonkuk,
Hope this helps.
