Why does my Blu Ray not work?
Doigy
Just tried to play Superman Returns on my VGN-AR21S with Cyberlink PowerDVD and it wont play. I've downloaded the firmware update for Matshita BD-MLT UJ-210S. Does anyone know what the problem is?
Also how do I get the motion eye to work?
Thanks
Adam
23 REPLIES 23
Doigy
Is it possible WinDVD BD is in my laptop box or is it as it says and just pre loaded?
profile.country.en_GB.title
tonybeard
Nah should be clearly preload
Doigy
It gets worse... Just tried using the recovery utility and it says " recovery partition has been deleted"... What's going on with my computer??? Any ideas what to do now?
tonybeard
Man you are in the dog house
Try yet try again
assuming you didn't make a dvd backup of your recovery partition...anyone reading this please I beg you ...make one
Thalamus.
Champion
Hi Thalamus,
I'm starting to think something is major wrong at the minute... I just tried to download the WinDVD BD from the Sony web site and it says I can because it's not been previously installed. I also cannot find anything on my laptop to do with the motion eye.
As far as I was aware that version of InterVideo WinDVD BD Version 8.0.08.100 was a full install not a upgrade..
Thalamus.
Champion
Just to be sure the recovery partition has been deleted you could try pressing F10 repeatedly when starting you vaio, this normally would start the recovery process.. (back up all important data first.. :wink: )
If that does not work and you have not created a set o recovery disc's, then you will have to contact Vaio-Link to purchase a new set of recovery DVD's..:smileysad:
Doigy
Any ideas how I can get my computer back to factory spec without the recovery utility or how to get my recovery utility back?
Have all over people using this laptop played Blu Ray without fail?
Doigy
Sorted it... Had to take off Norton Go Back... It changes the patition aparently
Thalamus.
Champion
If that does not work and you have not created a set of recovery disc's, then you will have to contact Vaio-Link to purchase a new set of recovery DVD's..:smileysad:
Doigy
When I do a recovery will it get rid of music and pictures on my computer or just installed software?
