I have recently uninstalled Cyberlink DVD player that came with my computer and I have installed Nero6. My remote button starts up my TV, Video, Music and Home Network, but not my DVD. When I press my DVD button I get a error message saying that USB102 cannot find the registry key of Giga pocket. Giga pocket might not be installed correctly. Has anyone had this problem and found a solution for it.
why dont u try un installing the nero and re install the original software you had???
Nero 6 isn't a DVD playing application. You shouldn't have uninstalled WinDVD.
Even if you had installed another DVD player it wouldn't have worked with the remote control. You need to reinstall & use the supplied version of WinDVD from the application recovery disk.
The remote only works with WinDVD, just tested it now.
remote control, mine also is not working, but I connot find WinDvD. Was this delivered with my Vaio PCV-W1? It did not work with Giga pocket, although that did start the DvD I entered.
No you have PowerDVD Harry
Indeed, and I tried this again. So I started power DVD, turned op the keyboard [Vaio PCV-W1} and pressed dvd on remote control. Giga pocktet then starts automatically. So I stoppen Giga pocket first, to see how things went with power DVD . then at pressing the remote control om dvd , the error [usbsircs] USB102 "Cannot find the registry key of Giga pocket. Giga pocket might not be installed correctly." So how do I solve this problem? Both Gig Pocket and Power DVD do not react on remote control.
Reinstall the utilities from C:\Utils
Just done the reinstall from C: utils, but that had no effect. I started with power dvd, turned the keyboard, pressed dvd on the remote, giga pocket did start [as the only dvd player for this remote control?] and gave the same error on the regsitry key.. Any other suggestions?
I know this sounds wierd, but did you install DirectX lately?
