New Sony A7 IV not turning on
SOLVED
profile.country.RO.title
macoleo
I bought a new body A7 IV and after a few pictures, I switched off and when I tried to switch on, did not turn on. In order to start the camera, I pull out the battery, waiting for few seconds and then put it back. This issue happened two times in first 200 pictures I took. Just to mentioned that before to start using the camera, I download and install the new software ver. 1.11, available on Sony site. Is there any other person who had the same issues? What is the reason for that issue? What is the workaround for this problem?  Thank you for your reply and support!
1 ACCEPTED SOLUTION
Accepted Solutions
HannahEd01
Hey macoleo, try initializing the settings: https://helpguide.sony.net/ilc/2110/v1/en/contents/TP1000616558.html
Work for a while with the factory settings and test it. If it worked, then it's a setting, start changing the settings one by one and test. If it kept happening, let me know.
6 REPLIES 6
HannahEd01
macoleo
Hello HannahEd01, thank you very much for your reply and support. I will try and let you know. Anyway, in the last 3 days I did more than 500 pictures and that issue, did not appear so far.
danardeng
Contributor
let's keep in touch, tell us if it's solved also on long period
SkyNet404
Specialist
Glad to know it's working fine mate! If it happened again though let us know, cheers.
macoleo
I am keeping my fingers cross! I did some more pictures and videos and the camera is working fine!
Piscie
@macoleo, great, thanks a lot for updating the thread guys!
