I have just bought a Sony NEX C3 body only in mint condition as a second camera to my a5000. I attached my 3.5-5.6 16 - 50 kit lens from the a5000 to test the C3 and everything looks great apart from some vignetting at 16mm, which I don't get with the a5000. Any ideas? Thanks.
Solved! Go to Solution.
To see the same effect on A5000 you shuld tourn off the Shading Compensation
This option is unavailable on MEX-C3 and you'll see the real lens effect.
