Notification Issue
SOLVED
MNBRG
Notification Issue
How can i remove the notification of android about 'lifeblog is working background'
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
@MNBRG now I understand. To remove that, do the same steps as I explained before (press longer on the notification). Then, select all categories. Scroll down to apps running in background and set the importance to low.
alexdon
7 REPLIES 7
MNBRG
_alexdon_
@MNBRG do you still want to use lifelog or just remove the notification?
alexdon
MNBRG
Yes im using lifeblog is there any solution?
_alexdon_
@MNBRG drag down the notification bar, tap longer on the lifelog message, select more settings and turn off notifications. I am afraid this will block all the notifications from lifelog but will also remove it from the top screen.
alexdon
MNBRG
Thanks i closed notifications about lifeblog but lifeblog isn't my problem. Android system notification is still there(about background apps)
_alexdon_
alexdon
Nazir30
Notification cant come down....
