hi
i just bought the mw1 but it doesn't work with the phone's applications with my xperia v ... the audio works well. i have smart connect and the mw1 official app installed on my phone, and i can choose which apps enable or download in market. but this apps seems don't communicate from phone to mw1, indeed on the mw1 i cant see the clock and the application icon. i updated the software version with update service, but it didn't fix the problem.
any advice?
thanks
Sounds like the app is not getting a connection to the headset. Try reinstalling the app in the phone and then restart the phone after you have installed the app.
well, thanks so much ... it worked!
now i can use the applications, but it didn't fix an annoying problem i always had: every audio sources work fine but when i use the mw1 during a call phone, who calls me hear a big voice delay.
anyone never had similar issue?
Bluetooth should not give any noticeable delay. Does this happen in all calls and only when you use the headset?
If you're using VoIP, please try a standard call.
