Wi-fi, bluetooth & mobile data problems on Z2
gigiduru
Hi!
The raw data: Xperia Z2, Lollipop 5.02, 23.1.A.1.28
The story goes like this: flashed my X2 on friday, everything worked perfectly for 24 hours then Wi-fi&bluetooth stoped working as in this message: /t5/Xperia-Z2/Wifi-and-bluetooth-won-t-turn-on/m-p/986337#U986337
The action: cecked antivirus and any anti-anything then uninstalled them; checked the wi-fi hardware with 3 other phones, a tablet and a laptot - works just fine!; performed soft reset; performed hard reset; try checking hardware using the hidden service menu *#*#7378423#*#* and it told me to turn on wi-fi or bluetooth (Doh!!!). All this time the Lollipop incorporated diagnostics software says it passes the test for Wi-fi (can I get a wt... is going on here?!).
The difference: Now my mobile comunications are down. They were down yesterdy morning, then worked in the afternoon after another hard reset then ... nothing, yet again! I checked the SIM card, it workes perfectly.
From where i"m standing it looks like a software issue. Any thoughts on the matter?
Thanks in advance!
2 REPLIES 2
Thommo
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
gigiduru
So ... it didn't work. I did that twice, once last week, once just now. Thanks for the solution anyway. I think I have to be patient for another update to be released and if it doesn't work even after that one ... we'll cross that bridge when we get there. For now I have to live with a non-smart X2. On the good side I didn't charge my battery in days :)))).
