Sony Ericsson Xperia Mini Pro(SK17i) Problems
azharstyle
my problem is if i bluetooth open then phone restarting again n again quickly i want help plz help me....reply my email & mobile no.
2 REPLIES 2
Thommo
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Hampus
Champion
Do you mean that the phone restarts when you activate Bluetooth? If yes, I suggest that you perform a software repair on your phone via our program PC Companion:
http://www.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
Follow the instruction that appears in the program and do not connect your device until this guide tells you how to connect it.
