Smartwatch 2 Click widgets in a corner
SoapWater
 Hello everybody,
I want to ask you, if it's normal, that when I place widgets in the corner of the watchface screen, that I have to hit them more in the middle of the screen?
Here an example how I mean this:
So when I place the widget in the upper left corner, I have to tap it a little bit more downright, instead of tapping it directly.
I'm happy about answers
- SoapWater
1 REPLY 1
Hampus
Champion
I'm unable to reproduce this behaviour. Is it for all widgets that you add in this corner that it occurs or someone specific? Have you tried to reset your SmartWatch 2? If not, I suggest that you give that a try:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=smartwatch-2-sw2#Resetting-you...
