Power and volume keys doesn't woark
Proday83
Last night i left my phone on charging completly normal; it woarked 100%. In the morning I remove phone from charger and power with volume buttons doesnt woark. It is good that I can use double tap to start phone and use it, but if I discharge all battery I think it will be impossible to power the unit again Slightly_frowning_Face Anyone had same problem, any solution for it?
7 REPLIES 7
Uliwooly
@Proday83
That seems more like a hardware issue rather than software, contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
Proday83
There is no local Xperia Care in Serbia 😞
Uliwooly
@Proday83
What if you open the SIM cover > press the red button?
The repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Proday83
Ill try that when arrive to my home from woark. Tnx for trying to healp mate.
Uliwooly
@Proday83
Keep us updated.
Proday83
I will. Just to check, i have only yellow button (write OFF below), did you think on it? And should i press it and keep it inside few seconds or only to press and leave?
Proday83
I install NDR utils, after restart, everithing woarks fine (for now). Ill see what happens when I plug phone on charger later.
