Possibly bricked, maybe dead. Oops.
starcoaster
A bit of black market under the radar dealing for spare parts landed me an xperia SP with a good glass screen so I could fix my smashed cover glass. What neither me or my friend realised is that his phone, although water damaged, operated, but the battery was toast. I ordered a load of genuine spares, a Cover glass panel, new battery, new backplate and cover and it ran fine a couple of days ago when not in the frame. However. Today, i got the touchscreen and I've tried to boot with everything connected, bearing in mind i had tested it all on my own SP to make sure it all ran perfectly. I've encountered what i assume to be a system recovery state. I'll attach a picture. It's got a bar at the bottom that has whizzed along for over an hour now without booting further. It gave the usual three buzzes for a dead battery on boot and took a few minutes to gather enough power to boot up at all. I will stress that the system has been running and before i stripped it down for repairs i did install the latest software on it (it hadn't booted or updated in over 7 months).
Is there anything i can do, or is it bin-fodder?
10 REPLIES 10
Thommo
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
The bar you see is the operating system trying to update and the 3 buzzes you mention is your phone been switched off,
So I guess that due to non use etc and no battery been connected it's lost the bios or in this case the eeprom settings so hopefully following the above will bring this back to life
starcoaster
it eventually booted, however, i have a new, more troublesome problem. Half of my touchscreen is dead, unsure as to why, could this be a hardware fault or some kind of spacing fault? I did wipe over the inside of the screen with a cloth with a small amount of fingerprint remover on and then wiped it with a dry microfibre after, but this was to both halves and only one half is non functional. The phone is working perfectly otherwise.
Thommo
Is the digitizer connected correctly ie: half in half out etc or is there any dirt blocking the pins/connection plug
starcoaster
i'll take it apart and look, i'll let you know if i found anything or disassembly then reassembly solves the problem
starcoaster
digitiser connection checked and re-seated, no change
Thommo
Which leaves either the motherboard connection faulty or the digitizer connection faulty
starcoaster
I'm going to try the digitiser from my working phone, although, if it's a motherboard fault and it fries the other digitiser, i'm without a leg to stand on
starcoaster
i swapped the motherboards over, it's definitely the digitiser
Thommo
Cheaper and easier to replace - Not all doom and gloom
