Can you tell the version of the firmware?
There were some issues in .757 but those were fixed.Could you try to clear data for sound enhancements under settings-apps-all and restart the device?
is your sony phone having quite often contact with liquid or water?
because volume low is normal to happen after liquid contact.
after you rinse ith clean flow tap water (of course all the cover must be tight), and you wipe dry the whole body, few minutes you will get the normal volume back.
hope this help
