Hi, I have the Xperia Z3, Until recently, my phone was fine. About 3 weeks ago it started disconnecting from my home wifi, this is extremely annoying. It does it when it feels like. Mostly when ive been idle for a bit, but does occur at other times too, in the middle of a written conversation it disconnects.
Things ive tried:
Resetting Router, moving it.
Resetting apps on phone to default.
Forgetting the Wifi connection and re connecting it.
Its doing my head in now need it sorted.
Any suggestions / fixes?
Just turned it off, I will update you in 24hrs maybe less , see if it fixes it. Appreciate the reply
Still disconnects. Dont know what to do
I am assuming you have checked in the Advanced WiFi options that "Keep WiFi on during sleep" is set to "Always"
Yep, its on always. never changed it
Going to replace my router see if that fixes it
The only resolution I can see here would be attempting troubleshooting with the router, the worst case scenario may very well be a replacement router, however you are best to seek assistance from the router manufacturer first.
