I buyed a sony xperia z2 mobile phone, when I setup my exchange push mail in it, I got problem, I can't connect my company's mail server. so I did some reserch about this issue, the answer like below:
I found a technical document from internet, below is the link:
I find that Exchange ActiveSync 12.0 can't connect very well to exchange server 2007 sp1 and above.
so this is the root cause why sony's mobile phone has problem to connect exchange server.
I don't know why sony's developer. so now I have to change back to use my Iphone 5s.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Xperia Z2 support Microsoft Exchange ActiveSync protocol version 2.5/12/12.1/14/14.1. Which of these versions that is used depends on what server you have and the settings in the server.
Could you describe the problem a bit more detailed and what happens? Have you tried over both WiFi and mobile network?
I have the same problem on my Sony Xperia Z2. Please help. Thanks
This means that you are not allowed to login using the details you have entered. First make sure that you are entering correct details. The username if often not the email address but the username you use to logon your work PC.
If you are not able to logon with the correct details you need to contact your IT-department to check why you are not allowed to logon.
Dear Rickard :
I am a IT staff of a company ,
We had found all SONY mobile devices having different kind of issues when using our exchange 2003 account .
Some can't reply mail , and some are fail to send a mail with attached file .
We had check exchange log and found all SONY mobile devices using EAS-2.0 to access exchange 2003 nomatter android 4.4.4 or 5.0.2 .
Pls see the follow discussion :
http://code.google.com/p/android/issues/detail?id=74465
And hope you can help to solve this problem , thank you very much .
Best Regards
