Dont' request private information, just upload them to box, dropbox, drive, etc and post the links
It's hard to see what's going on, on that screenshot, do this
charge the phone 100% > use it as you normally would > once it reaches 10% take the following screenshots
1. the same as the one you posted (the list with the graph)
2. tap on the top 4 items on the list an take a screenshot of each
3. tap on the graph and take a screenshot
post them all here or post the link like you did today.
I don't see anything wrong with your phone, I can see that you have a lot of stuff going on, btw you need to transfer some pictures, videos, music etc to your SD card as you are running out of internal storage, also, it's hard to see the graph like that, what you have to do is
1. charge the phone 100%
2. restart the phone
3. make sure that the phone is still at 100%
4. settings > power management > battery > tap on the graph > take a screenshot once the battery is down to 10% but do NOT charge the phone inbetween.
Bad signal reception also can cause battery drain, especially if you are using an intensive mobile data., used to experience it.
makes my battery life 40% quicker drain.
