Auto Home WiFi Connection
cobbler
Usually when I return home my phone will switch from mobile packet data to connect to my WiFi, however tonight it didn't, the wifi list showed my hubs name but it said out of range, after turning off phone then restarting it did connect, but why did I need to do this?
Phone isn't using stamina mode and is already set to automatically connect.
Tags (1)
16 REPLIES 16
Uliwooly
@cobbler
Disable stamina mode > restart the phone > check again.
cobbler
Can I just confirm, you say disable stamina mode even though I wasn't using it?
cobbler
I already have Location Based WiFi enabled.
Uliwooly
@cobbler
I thought you said that stamina mode was on, if it's not then do you have any antivirus? taskillers? battery apps?
cobbler
Nope.
Uliwooly
@cobbler
boot on safe mode and check again.
cobbler
Cheers, but it connects as always, its the times when I have been out then get in range of my hub.
Uliwooly
It's an app acting up, third party app
@cobbler
cobbler
I don't have any third party applications installed.
