Android System Battery Drain
gr10
Hi All,
My phone is discharging at a rate of about 6% per hour, when Idle.
Android System  consumes about 15% battery, which I understand is excessive. In the pics attached it shows which packages are in it.
Can you please tell me what is safe/possible to disable?
10 REPLIES 10
Uliwooly
@gr10
Boot on safe mode and check again, most likely it's an app acting up
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Uliwooly
@gr10
I also noticed that you have apps running all the time, such as battery apps, weather apps, antivirus? ram apps ? booster, cleaner apps?
gr10
Hello and thanks.
I rebooted in safe mode, but since GSam is now disabled I can't quite compare.
Under Battery Usage Android System is 3%, but there is still a lot of stuff in there.
The battery apps were just installed today and yesterday to try to understand where the problem is. Although I am not aware of those weather apps, antivirus ram apps and so on....where did you see them?
Uliwooly
@gr10
I only saw the battery app, and I was asking about the other apps.
You can go to settings > power management > battery
gr10
no, nothing like that, I am really keeping it to the minimum.
last night I left the phone on in airplane mode, with 57% battery, this morning it was off (so it can't be connectivity related).
I don't believe the problem is "just lollipop", there must be something in the background going beserker and creating noise.
Android system at 15% is unusual, isn't it?
Uliwooly
@gr10
It'll be wise to repair/reinstall lollipop with PCC, it will smooth things out. Run PCC > support zone > repair the phone
PC Companion (PCC)
Bridge (for Mac)
gr10
 I forgot to mention: I did that already, besides restarting the phone with the yellow button next to the sim card.
Uliwooly
@gr10
Try this
Reinstall lollipop > do NOT install any of the apps I've mentioned before, uninstall any antivirus app that was included with the update > charge the phone to 100% > use it as you normally would > once it reaches 10%
take the following screenshots
settings > power management > battery > take a screenshot of the list
tap on the graph > take a screenshot (landscape works better)
back > tap on the top 4 items on the list > take screenshots
post them all here.
gr10
Thanks.
Is this process absolutely necessary? Under power management - battery I only have 4 things now, I don't see how after reinstalling everything this can possibly look better... ?
interesting to see how Android system is only 3% under power management but 15% under GSam. Why is that?
