I need help...
Tadeorivera
I need help...
I need help...
How can I block incoming calls from numbers that I do not have registered?
Necesito ayuda...
Como puedo bloquear las llamadas entrantes de números que no tengo registrados?
2 REPLIES 2
Uliwooly
@Tadeorivera
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Unfortunately there isn't a preloaded filter app and/or setting to do so, here are your options:
you will need to download a call filter app
or
contact your carrier network and request them to block any unknown numbers.
Jonas
Master
Hi @Tadeorivera, welcome to our forum!
Do you want to block callers from hidden numbers, or just from numbers that are not in your contact list? The call block feature requires you to add the number to the list, either after the call has been received, or if you already know the number(s) you want to block.
If you want to block calls from hidden/private numbers, you will need a 3rd party application as @uliwooly mentioned as this is not available in the device by default.
