Hello,
I've just bought a Walkman NW-A45 and I'm having difficulty adding my existing music library to it.
Firstly I added a micro SD card and formated it using the settings on the Walkman. Then I downloaded Music Center for PC and then selected import folder and selected my iTunes Library which is about 72GB and has roughly 13k songs. Music Center has managed to import many of the songs but once it was finished it displayed a pop up explaining that some of the files (a big % of my library) couldn't be copied across.
The error code is: 24667, unable to read file. I've googled this error and can't find any explaination.
As far I am aware all of the files in my iTunes library are MP3 files with a bit rate between 192 and 320 so I'm not sure why some of them are copying over and some are not. I didn't buy any music directly from iTunes either.
I also have some music files on my PC which haven't been put into iTunes which are MP3 and 320kbs and I'm getting the same error message so it's not just an iTunes problem.
Any idea what I'm doing wrong / can someone help?
Thanks,
David
