WH1000 XM4
SOLVED
Jamesanwell
WH1000 XM4
Recently acquired noise cancelling headphones. There was a definite sound bias to right hand earpiece. Returned unit and replaced headphones via a different supplier.
Having same problem.
Sony say there is no facility to alter balance
Has anyone experienced similar issue?
1 ACCEPTED SOLUTION
Accepted Solutions
IamNic
Hello @Jamesanwell,
@Jamesanwell  wrote:
Not sure what you mean by playback device
The device you have the headphones connected to and play your music from.
@Jamesanwell  wrote:
I’m using my new earphones with an iPhone 11
That answered my question.
for iPhones you can adjust the stereo balance: https://support.apple.com/guide/iphone/audio-visual-iph3e2e2cdc/ios
I assume you altered that setting in the past by mistake.
Can you please check that?
- Nic
6 REPLIES 6
IamNic
Hello @Jamesanwell,
unfortunately you make no mention of the playback device you are using - yet from your description it sounds to me like the pan (balance between left and right channel) is shifted on the playback device (software or hardware wise) as it occurs with two individual sets of headphones.
Kindly let us know what device you are playing music from.
- Nic
Jamesanwell
Hi Nic,
Not sure what you mean by playback device.  I’m using my new earphones with an iPhone 11, listening to music either downloaded and saved or via Spotify or other similar streaming platform.
thanks for your help
james
IamNic
Hello @Jamesanwell,
- Nic
Jamesanwell
Sometimes the solutions are so simple!
All sorted, thanks Nic
James
Joe_Dohn
Specialist
Glad to hear your issue was resolved!
It'd be really helpful to others if you mark the thread as solved so the solution is easily accessible to them in the future ^^
- JD
IamNic
Hello @Jamesanwell,
you're very welcome.
I have heard about the setting causing the described issue on reddit before, so it was my first guess after you mentioned the iPhone :slight_smile:
- Nic
