WH-1000XM3 won't charge
SOLVED
kbarnak
I recewived my headphones yesterday 11th Septemebr 2018 and they just won't charge. Tried on Mac tried on USB charge but they won't charge at all. Sony Help Guide for previous model WH-1000XM2 says charge directly to a computer - Why?? The computer must not hibernate, Anyway Ive done all that and updated them because I managed to pair them (with the Sony Headphone App showing the battery empty ) to my iphone. They just will not charge.
I had tried before pairing them to the iphone , to reset to factory settings but that didn't do anything.
I'll be taking them back.
1 ACCEPTED SOLUTION
Accepted Solutions
jumpsuit
Hi @kbarnak
Is there any particular reason you're not plugging the charger that came with them
 into an A/C outlet?
If you have and they still dont charge it may be worth testing another lead.
(Edit - apologies to @IamNic. regarding the possible broken lead, you posted while it took me ages to type lol)
21 REPLIES 21
IamNic
Hello @kbarnak,
maybe the cable is broken.
You are right, that it shouldn't matter, if you charge it on the USB-port of a computer or on a phone-charger.
- Nic
jumpsuit
Hi @kbarnak
 into an A/C outlet?
IamNic
No harm done :wink:
kbarnak
Thank you very much jumpsuit for pointing out my mistake. Like I ‘d said , I had tried charging via Mac and via USB hub. Success came when jumpsuit prompted me to read instructions ‘ attach cable to USB AC Adapter’ , so , they’re charged and pretty wonderful.
Happy I asked Community to help me- Cheers
Keith
jumpsuit
Hi @kbarnak
No worries :slight_smile:
Glad they're sorted.
KE55ARD
My headset absolutely will not charge either. I got it a few days ago and it charged on the first day up to about 60% ok then I let it do an update...
Since then every which way I've tried charging it has not worked. The little red light comes on to SAY it's charing, but no matter how long I leave it for, when I unplug and repair it says 10%, then complains about low battery and turns off.
I've tried the cable it comes with plugged into my laptop, an AC adaptor and a portable battery.
I've tried a USBC to USBC cable from a charger in my car and from the same portable battery but nothing seems to get the charge level up since the update (which added alexa or google assistant or some crap).
Pontsius
I have the exact same problem when charging. Tried charging in all differnt ways. But either way it says it is Now ok battery.  Had it One day, after first charge it was 60% then i made some program update and after that... Doesn't work...
corycorycorycory
I have had mine for about 2 weeks and suddenly they won’t charge past 60%. I have tried everything. Different power adapters, reset
KE55ARD
To follow up my previous post, just want to let people know I managed to get mine successfully repaired under warrenty with Sony, so if anyone else is having this issue this is probably your best course of action.
