EU volume cap nwz-e455
profile.country.it_IT.title
moriero85
Hi....i removed the EU volume cap(before the audio was very very low) at my nwz-e455 with a method  that i read in a forum. Now the volume is ok...but  the FM frequency is set to 76-90Mhz (JAPAN range) . If i restore
the EU cap, the fm frequency range will change again? It's possible to restore the limit of 85db in the service menu?
Thanks
1 REPLY 1
profile.country.el_GR.title
drotsolas
can you say me also this method because i have the same problem with you. the volume level is too low. thank you very much.
