I have recently bought a Vaio (to replace my old Compaq). When i connect the Vaio to my wireless connection, it connects but gives the description as 'connected with limited access' the reception is excellent and the router is recognised. I cannot work out at all how to get past this to connect to the internet/outlook. Please help
Welcome to ClubVAIO![]()
Are you sure you have the correct key?
If so then try running the attached file.
Does this help?
What router are you using?
On your compaq look at the default gateway, ip etc and change your vaio to be the same. (turn off the wireless on the other machine) Do you get a full connection with this information?
Its a speedtouch that was supplied with AOL, my knowledge is not good enough to manually set ip addresses etc
I will try and give you a step-by-step guide.
I presume your Compaq is an XP machine and your VAIO is a Vista machine?
On the Compaq:
Start -> My Network Places
Double click on your connection.
Click Details on the support Tab
Take note of all the numbers.
On the VAIO:
Start -> type "Network and sharing center" and hit enter
On the left hand plane click on manage network connections.
Double click on your wireless adaptor
Click on Properties and say continue when asked by UAC
Click on Internet Protocol Version 4 and press the properties button.
Click on use the following IP address and fill in the information from the other machine. Click enter and restart the machine with the wireless off.
When it has started up turn the wireless back on and see if it connects.
Does it work?
Yes
Yes
Thank you for the clear instructions. Nothing has happended and the two small computers (by the clock) have a yellow triangle with an exclamation mark inside?
