I have a FS115B sony laptop and I was wondering weather some one could tell me what that connector thing is underneath the laptop I persume you plug something into to it but what?
Thanks
Does it matter if they are '-' or'+' as the drive is supposed to work with both?
You can use either...
Jenny - Is the "speed" of the disc compatible with the drive?
E.G.: My drive is upto 4X so I can use 2X and 4X discs - just a thought.
Good Luck
nice thought, thanks. The discs that I bought are Maxell 1-4x speed R+. Drive is supposed to be 4x so should be ok I thought.
Hmmm, will it play normal DVDs?
Just wondering if its a sensor problem, dirt etc...
Maxell should be fine.
Plays DVD films.
That's one good thing
