hy all,
Is anybody use the internal memory stick duo pro reader for using readyboost capacity?
if yes, witch memory card do you use?
thanks
Have a look here - it lists which media is compatible with Readyboost.
http://www.grantgibson.co.uk/misc/readyboost/?make=Sony
thanks for these usefull link
this list and the results are insufficient and confusing. Some results claim the Sony Memory Stick ProDuo MagicGate MSX-M2GN (which would be ideal for ReadyBoost) for compatible, but they don't tell the testing enviroment. Wether the memory stick is readyboost compatible depends strongly on your model of cardreader, which are different in the vaio notebooks. Sometimes I doubt, that a product line of vaio notebooks has built-in always the same cardreader with the same specs.
Therefore: try and error.
Fyn
Anyway, all tests I've seen are proving this is again a useless technology, that gives NO improvement, except for those who get very small quantity of RAM. Who I suppose won't be found in this forum
