I Cant seem to upgrade my bios anywhere in the world except a pay site which is quite annoying as i cannot afford it. someone please help as i am a my wits end. my details are as follows.
AMIDIAG Suite tests and diagnoses every hardware subsystem on your PC! A professional tool for developers, manufacturers and technicians.
AMIBIOS Motherboard Identification Utility v 1.4
This file has recorded information useful in identifying the manufacturer of this motherboard. You must contact your motherboard manufacturer for support. For more information on upgrading your BIOS go to www.ami.com/bios.
Note: The BIOS manufacturer in most cases is not the manufacturer of your motherboard.
BIOS String info:
An AMIBIOS ID String Was Detected:
63-0500-000001-00101111-100104-SPDALE_G
| | | Chipset/BIOS Info
| | BIOS Build Date
| Manufacturer ID
BIOS ROM Information
AMIBIOS ROM Size: 512 KB
BIOS Build Date: Oct 01 2004
Motherboard Manufacturer Code: 0001Not listed in MAN.DAT file
AMIBIOS Build Tag: MUKA1026
AMIBIOS Project ID: MUKA1026 Not listed in TAG.DAT file
SMBIOS info:
Manufacturer : ASUSTek Computer Inc.
Product Name : P4SD-VL
Case Code :WTM20070629246518275
Our system has received your mail enquiry. ASUS Technical Support Engineers will be responsible in replying your mail within 48 hours on Mon~Fri (except public holiday). If you have not heard any response from ASUS TSE, please check for mail reply status from the link below. Thanks very much.
http://vip.asus.com/eservice/techmailstatus.aspx?ID=WTM20070629246518275
Hi rizze,
welcome to Club vaio..
Depending on your Vaio model and if an official Sony BIOS update is available it can be downloaded for free here ..
Welcome to ClubVAIO
What machine do you have?
Which Operating System (XP or Vista)?
I have windows xp Media centre edition
What VAIO model do you have?
Hi Rizzie,
What model Vaio do you have..?
Did you check the link I posted above to see if there is a Sony BIOS update available for your Vaio model..?
Hi rizze,
What does the serial number check say that the model is?
What model do you have and what BIOS version do you currently have installed?
Model no *********** Serial no ******** p4sd-vl
edited: to remove serial number
