- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony HT-ST5000 soundbar doesnt work
I have big issues with my Philips 65oled854 and sony ht-st5000 soundbar.
When turning on the tv the soundbar also should power on because of HDMI CEC, but that is not the case. 1 out of 20 times it works.
Newest software on TV and soundbar.
Is there a way to fix this? I thought hdmi cec was standard! It is called easylink on philips and yes it is enabled.
The soundbar works great with nvidia shied. Hdmi cec works perfectly. I turn on the nvidia shield and soundbar switches input.
Any way to debug this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I believe turning on the soundbar should turn the TV On, not the other way around?
That said, make sure it is enabled using the steps in the Manual (page 52, "Control for HDMI").
- JD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That doesnt work either. So something must be wrong here.
Control for hdmi is enabled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Latest software on tv and soundbar. Tried different hdmi certified cables.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you happen to have anything else connected to either of them that uses HDMI? If yes, try removing everything and just use the soundbar and TV and see if that solves the issue.
I've seen some users reporting that some devices cause interference, maybe you have a similar thing going on?
- JD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello. I have tried that as well. Disconnected everything. I also tried all HDMI ports on the TV that supports ARC.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey there ^^, I suggest resetting the soundbar as described on the Manual page 71: https://www.sony.com/electronics/support/res/manuals/4687/177e67ef0b6478b983b4b6190e14b9c1/46878383M..., then make sure the HDMI control is enabled and try a power cycle by unplugging everything from the mains. Try to turn the devices using the remote of the soundbar first and see what happens. Let us know if that worked ^^
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have done that several times. Doesnt work.
