KDL-43W805C 3d picture error
durbass
Hi
i watched a 3d movie and all the way through the movie i had vertical lines...... any ideas on the problem
5 REPLIES 5
Anonymous
Not applicable
Hi there,
Have you tried a factory reset?
Best wishes,
M
durbass
Hi
I have tried factory reset, but still the same.
Rob
Drewde
Administrator
Hi Rob,
Is it just this specific film or every film you try? Does it happen when you're using other inputs? What device are you using to play the film?
Drew
durbass
Hi Drew
Its on all 3d films plus when i 1st turn on the tv i get i thick red line at the bottom of the tv horizontal about 6 inch's high all the width of the tv, and after 10 mins it dissappears.
Rob
Drewde
Administrator
Thanks for the info. The Sony Support team will be able to help further. You can reach them here: https://services.sony.co.uk/supportmvc/en/Contact/Email
Thanks,
Drew
