- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-55AF8
Hi
As im new to this tv would you answer a couple of question.
1, Pressing the power button on the remote does not completely turn the tv off hence the sound bar will stay on, with my old tv when i turned on or off the sound bar would follow suit so i have had to disable the auto power.
2, The remote is quite basic so when im watching a film and want to expand the picture to remove the black bars i dont know how or if its possible.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ushert wrote:Hi
Thanks in advance.
Hi @ushert
1. What happens when you enable auto power on your soundbar (make & model?). My soundbar Sony HT-ZF9 Power off/on follows the TV.
2. If aspect ratio is available for the input (probably won’t be on 4K) press [Action Menu] on your remote and select Wide mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
When i enable auto power it does not turn off, My soundbar is a Samsung HW-H55O. I have also checked the action menu and there is no wide screen.
All tvs i have had could zoom but not this one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ushert wrote:Hi
Hi @ushert
Make sure HDMI Control (CEC) is enabled on both TV and soundbar. Also that the soundbar is connected via HDMI (ARC). [Action Menu] -> Sync shows control available for your soundbar.
Your TV should have “Wide mode” available if the input is SD or HD. Try Digital BBC One and see if Wide mode is available.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks very much, optical now changed to hdmi arc and works great.
Still no wide mode but im sure i will get there.
thanks again.
