I am trying to unscrew the small screws of the LCD screen with a 1.4mm screwdriver but it seems to big for the screw, what size do i need?
I used a 1mm screwdriver and managed to open and remove the old screen, i had to pull away the plastic casing from the old display, but the new screen is loose in the casing,how does it secure?, when i re-assemble camera it is very loose along top edge, is their a technique?
Thanks, but i needed to use super glue to fix the LCD to the frame and now the glue seems to have leaked through and affected the screen appearance, it doesn't affect outcome of photos though.
