Proximity Sensor Issue for Xperia XZ
klay79
Well the normal situation when in call and the phone is near the ear the screen will turn off and when you put away the device for example to dial a number the screen turn on to make any operation. In my case it stays off all the time until I either end the call or to put my finger over the sensor to turn it on ( its not just simply put a finger it involve alot of hassle) I've preformed software repair using pc companion but unfortunately it didn't work.
Any suggestions other than take my devive to service center🙏
11 REPLIES 11
Uliwooly
@klay79
Is there anything covering or partially covering the proximity sensor, such as a protective film, glass?
klay79
No nothing is covering the screen.
Uliwooly
@klay79
Could you test your device?
Settings > About phone > Diagnostics > Test
Oreo
Settings > Support > Tests
klay79
Yes. Its clear that its not working! Is there any precise patch for this issue or its not common!
Could it be hardware malfunction ?
Uliwooly
@klay79
Do you have the latest update? which android version and build  number is your phone running?
klay79
Supposed this is the latest build  and update
klay79
Supposed this is the latest build  and update.
What do you think?
Uliwooly
@klay79
Sadly I can't see the screenshot until it gets approved.
klay79
Any suggestions?
