Yellow light when connecting to usb
BlinkingRiki182
I wanned to replace the LCD and the touchscreen.
Bought the parts, replaced them and now i get an yellow light when i connect the phone to the power or the usb.
If i put the battery inside and plug it to the power or the usb, no light appears at all.
I'm afraid i have to throw the phone in the trash now Slightly_smiling_Face What does constant yellow green light mean?
3 REPLIES 3
Samuel1
Hero
Well, there are several things that uses the notification light so it's hard to say what causes this actually.
BlinkingRiki182
It will be plenty helpful if you can tell me which ones are these Slightly_smiling_Face
It shows the green - yellow light when connected to the usb and the light goes off after about 40 seconds.
If the battery is in and i connect the power cord to the phone, no light pops up at all. If I then let the power cable in the phone and remove the battery, the green - yellow light appears again.
BlinkingRiki182
I found the problem - the new Touchscreen that I bought is either defective or isn't compatible with C2005. I disassembled the phone and attached the old Touchscreen - the phone worked OK. As soon as I attach the new Touchscreen I get the described behavior - yellow / green light that goes off after about 30 seconds and no function.
