hey .
i have xperia z1 and it working fine but i have issues when i charge my phone
after it on 14% its make a lot of disconnecting and connecting {on and off}
i check my charger on other cellphones and it worked fine and other chargers make the same problem with my xperia z1
my kk is 4.4.4
can you help me with my problem?
thank in advance
Daniel,
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
