Wifi connection issues
Jimbob74
I've had my phone for a a few days now and it's been connected to my home wifi with no issues whatsoever for the first few days, but as of last night it will not connect at all.
In Wifi settings, I can see my home network and it shows as Saved, secured with WPA/WPA2.
When I try to connect to it, it is showing 'Authenticating' but then does not connect.
All my other devices, PC etc are connecting to the network without any issues so I know it's not a problem at the wifi end.
Can anyone help me understand what I should do on the phone to try and get this working again please?
13 REPLIES 13
profile.country.RO.title
_alexdon_
You could try to forget the network and add it again.Also,take a look here:
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104#U348104
alexdon
Beautifuleg
Hi
I have the same issue as Jimbob74 has. I'm trying to connect the Z2 at the network created by a GoPro camera. I can see the network, I can enter the password, then the network is saved. when I try to connect the network goes to authentication but at th end does not connect. I canceled the network and tried to connect again several time without success.
I have a tablet and another phone and works perfect with both of them.
Do you have any suggestion?
Thanks
_alexdon_
Did you check the above topic?
alexdon
Beautifuleg
Yes
I followed the instruction where possible, but still I have same issue, network saved but does not get connection.
_alexdon_
That is strange indeed.How about if you change the protocol to WPA-PSK?
alexdon
Beautifuleg
So you mean on the camera's network?
_alexdon_
Yes.do try it.
alexdon
Beautifuleg
I'm not a great expert but I think I can't do it. on a GoPro camera.
Beautifuleg
Solved Thanks a lot!
