Sound features quit working
MM269
Updated to lollipop on a tmobile xperiaz3, all old sound features quit working. What to do? Need help
2 REPLIES 2
Thommo
Sounds may have changed with the updated firmware so old sounds may not be available however you could try a system repair
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Uliwooly
@MM269
Reinstall lollipop with PCC
PC Companion (PCC)
Bridge (for Mac)
