I had bought this xperia sola 2 weeks ago.....it worked like butter since then till today morning......when i discovered that it's touchscreen is not working properly.....
The touch screen is not responding as it should...Sometimes it sens and sometimes not...!!!
As you can see in video... VIDEO LINK : http://www.youtube.com/watch?v=IjkJaEathV8
1. it's difficult to unlock.... time : 00.04, 2.10
2. then you cant select or delete clock widget (when you touch and hold.....it presumes that u touched ones and opens the clock.) time :00.24, 2.48
3. Capacitive buttons are also not responding well... time :00.27
4. not able to change wallpaper......as when touching and holding in empty region.....it doesn't open the wallpaper widget menu.... time: 00.30, 02.22
TOUCH and HOLD is not working....
5. also it have problem in dialing numbers... time: 00.42
6. things doesn't changes even after restarting.... time :1.39
7. also have problem in app menu.... time : 3.40
In all the whole problem is of touchscreen response......
I have also rest it to factory setting and formatted it's internal memory.....(in case some setting or app has created this problem) but unfortunately that has also not helped.....
also .162 update is not unavailable from sony(it was available earlier)......!!
also sony companion is also not repairing my phone...it says that your phone is upto date.....
and update centre is also saying phone up to date....and is also not showing"update anyway" feature as suggested by some users....
PLEASE HELP !!! ....I have bought this phone just 2 weeks ago...
I bought the xperia sola and in 2 weeks time I too had a similar touchscreen problem(its an intermittent touch). I took it for service and they say they need atleast 8 days to fix this issue
i had already said u thats a firmware problem...
I already have .162 firmware and have the touchscreen problem.
im from the philippines as well.
I got the latest firmware but it doesn't make any difference... i think its getting worst.
Yeah no available part yet for xperia sola here in the philppines. This is an o going issue for 3 weeks now. Im gettings sick of this crap!
I'm also from the Philippines, phone from Hong Kong (branded via Three HK).
Three weeks after I bought it, my Xperia Sola's touch screen responsiveness started to act up. I thought it was some app that caused it as it was intermittent but after resetting the phone, nothing changed.
Now, as evryone have mentioned above, I flashed .162 to fix it but still to no avail.
Has anyone figured out how to get around this? Or have we given up. I actually, also, went to the store where I bought this but they insist that it is MY fault and pulled the usual sh*t - "due to bumps and accidental drops."
So what did you guys do? For those who haven't fixed their phones by flashing to .162.
Currently, I'm downloading a Russian version of a .576. I hope this works.
Thanks,
Daye
I just reset an updated to las fw 162 (now available) but I yet have the screen problems.
Any news on this?
Just try to update to .184. I didn't have this problem, but now, with this fw, display is more responsive.
184 is available?
Yes!
Where? Pc companion says I have the latest update 😕
Thanks in advance
