This issue appeared in 5.0.2 lollipop firmware on Xperia ZR. When I make a call and my screen is locked it's still active for 1-2 seconds. This leads to accidental hang ups, turning on loudspeaker and so on.
I was waiting for 5.1.1 update but Sony didn't fix that. The only solution is to lock the screen manually every time I make a call.
Yes, it's still the same.
The same problem on Z1 Compact:
/t5/Xperia-Z1-Compact/Proximity-sensor-bug-in-Android-5-0-2/m-p/998587#U998587
By the way, this issue was fixed in latest 5.1.1 update for Z1 Compact. It seems Sony knows about it, but it won't going to fix it on ZR?
Same problem with ZL.
Is any solution for that?
