problem with Z2 and dualshock 3 wirless detection
peekskill
hi i have an Xperia Z2 and i have a little problem with the dualshock 3 ... when i use the conectivity setting to pair them it says that it's paired but once i rempve the wire the dualshock3 goes off and there's no BT connection between them the DS3 works perfectly wired and works perfectly when i reset it and use it on a ps3 wired and wirlessly i made i reset to the DS3 before using it on the Z2 but nothing happened the Z2 BT works perfectly when i exchange files with other people ... thanks everyone Slightly_smiling_Face
Tags (1)
13 REPLIES 13
peekskill
i really don't know i guess no one can help us on that i guess we should buy a DS4 just to do that T_T
Uliwooly
Have you contacted your local Xperia Care?
TheToid
This is exactly the same problem I am having, since I updated to 5.0.2 on my Xperia Z2 my DS3 controller that connected flawlessly before I installed 5.0.2 no longer connects. Instead you get the generic Blutooth request which requires a passcode, there has to be a fix for this surelly? Sony just can't take away functionality from us.
TheToid
Ok, I worked out my problem, for some reason I had to reconnect my DS3 to the PS3 using the cable and pair wirelessly, then turn off the PS3 then reconnect it with the Z3 using the cable again, then from that point forward it worked iwth my Z2 again. I hope this helps other people.
