Problem with incoming and outgoing calls since 5.1.1
DefyM
Hello,
since updating my Z1c to 5.1.1 I've got problems with calling someone, getting called oder receiving text messages. When I try to call the call ends immediatly with a "beep" sound. Once in a while it is still possible to make a successful call oder receive one. But most of the time it isn't.
I do get notifications from my mailbox about missed calls but most of the time only one notification altough I missed five calls.
I have done a factory reset as suggested by the Sony support page - twice. The second one with deleting all personal data additionally.
What do I have to do to fix this? Thank you very much fpr your help
Best regards,
Moritz
5 REPLIES 5
profile.country.US.title
Qatrium
I'd suggest that you do a PC Companion phone repair, this will do a clean installation of the latest firmware and will also wipe your internal memory. And it's totally different and better than factory reset.
Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
DefyM
Hello Quester,
thank you for your reply. I reinstalled the latest firmware via PCC. Now I am able to receive and make calls but inbetween these calls the reception drops to zero once in a while, which seems suspicious as it never happened before the first problems occurred...
Are there any other steps I can make?
DefyM
The problem returned :-\.  Since today my phone doesn't have reception in unregular intervals. My SIM card should be fine as the problem didn't occur on an other device.
Any ideas?
medi
Same problem
hooray
I experiencing the same problems as well.
After each call my reception bar droped to zero then increase back.
and Also, if i pick up a call while i am using other apps/games, the phone goes restart immediately, should i go for warranty?
