i bought a new xperia l a month ago.when i would like to charge it,its not charging asoon i put the charger pin.after constantly trying 6-10 times its recognizing ang charging.so pls look after this issue
thanking you
it could be a charger issue or a USB socket issue.
Try to charge your device with a PC/Laptop with another USB cable
i have tried but the problem is with the cable.....will it be replaced or i shold buy a new one
If the power supply/cable is broken check the warranty policy for your country
http://www.sonymobile.com/global-en/support/phones/xperia-l/support-documents/
For example for UK is replaced in warranty
This Limited Warranty will last for a period of
two (2) years as from the original date of purchase of the
Product for your mobile device, and for a period of one (1)
year following the original purchase date of the Product for all
original accessories (such as the battery, charger or handsfree
kit) which may be delivered with your device.
